May 30, 2022, 04:58 |
Turbulent energy spectra
Rep Power: 4 |
Hi everyone,
I study flows in biperiodic channel and I would like to plot turbulent energy spectra in 1D (streamwise direction). I had the instantaneous fields of my 3 velocity components at a fixed distance from the channel wall (y+40). I perform a Fourier transform thanks to Python as follows: 1) I store 1 line of my instantaneous field of U in the streamwise direction in a vector (same for V and W) 2) I perform the FFTs: Code:
FFT_U=abs(np.fft.fft(U))**2 Code:
FFT_V=abs(np.fft.fft(V))**2 Code:
FFT_W=abs(np.fft.fft(W))**2 Code:
0.5(FFT_U+FFT_V+FFT_W) I obtain a 1D spectrum that have a shape in agreement with the literature (at the same friction Reynolds number) but the energy levels are significantly different. I am not sure about the formulae used to compute the kinetic energy spectra. Is the following expression right ? Code:
abs(np.fft.fft(U))**2+abs(np.fft.fft(V))**2+abs(np.fft.fft(W))**2 Sincerely, Boone |
May 30, 2022, 06:37 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
If you search in the forum, you will find several posts that answer you. I personally posted years ago a matlab script for doing that. |
May 30, 2022, 08:28 |
Rep Power: 4 |
Dear FMDenaro, thank you for your answer.
I effectively found these posts that help me proposing the expression I wrote in my first message: Plot Turbulence Spectrum Using 2D Spatial FFT Energy spectrum-wrong spectrum shape Energy Spectrum for a 3D turbulent Flow Computing the energy spectrum of a turbulent channel flow I plotted (abs(FFT(U)))^2+(abs(FFT(V)))^2+(abs(FFT(W)))^2 as function of the streamwise wave number. I am surprised by the energy levels which are very high when compared to the levels obtained by some author of the literature (see: fig 5. of Spectral analysis of turbulence based on the DNS of a channel flow Igor A. Bolotnov et al. 2010 Computers & Fluids) |
May 30, 2022, 14:31 |
#4 | |
Rep Power: 73 |
1) if you want to plot the 1D spectra, why do you sum the contribution of U,V and W? 2) If you are working with the non-dimensional equations, your velocity fields are already non-dimensionalized by u_tau. |
May 31, 2022, 02:54 |
Rep Power: 4 |
1) I thought that is was possible to compute the total contribution of the 3 velocities along 1 direction (streamwise, x). My mesh is homogeneous in this direction and in the spanwise direction (z). Isn't it the case ?
2) I am working with dimensional equations. My fields of velocity are in m/s. That is why I normalized by nu*Utau the energy spectrum. ------ Do you have any other idea that can cause this energy difference ? Is there a difference between the energy spectrum and the density energy spectrum ? Thanks ! |
May 31, 2022, 05:12 |
#6 | |
Rep Power: 73 |
The velocity is normalized by utau, therefore the first issue is in your computation of u_tau. Then, the kinetic energy is normalized by u_tau^2. |
May 31, 2022, 06:58 |
Rep Power: 4 |
In the literature, see: fig 5. of Spectral analysis of turbulence based on the DNS of a channel flow Igor A. Bolotnov et al. 2010 Computers & Fluids, it seems that the energy spectrum is normalized by Utau*nu [m3/s2] which seems coherent to obtain a normalized energy spectrum.
I think that if a want to first normalize the velocity I have to do: abs(np.fft.fft(U/Utau))**2 but the resulting energy spectrum will be homogeneous to meter. |
May 31, 2022, 09:52 |
Rep Power: 73 |
Yes. Spectral density has dimension m^3/s^2.
Have a check here to see if your different scaling is due to these issues https://journals.ametsoc.org/view/jo...-17-0056.1.xml |
fourier transform, spectral analysis, tke |
Energy equation - where is the turbulent kinetic energy? | usv001 | OpenFOAM Programming & Development | 1 | January 25, 2022 16:04 |
Contributions to turbulent kinetic energy in les | sonsonst | FLUENT | 2 | November 12, 2021 16:17 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
Turbulent kinetic energy at wall? | alanlove | FLUENT | 1 | November 23, 2012 12:24 |
LES and total turbulent kinetic energy | Boerge | FLUENT | 1 | September 8, 2012 12:41 |
