Secondary Flow Path Meshing for centrifugal pump using TurboGrid
Old   April 25, 2022, 07:59
Default Secondary Flow Path Meshing for centrifugal pump using TurboGrid
Mandar Patil
mandar55patil is on a distinguished road
I am simulating pump impeller with the secondary flow path to study the recirculation at impeller inlet. I am using design modeler and blade editor to define the flow path and the secondary flow.I have defined the hub,shroud,inlet and outlet contours along with the interfaces and walls of the secondary flow path. I have followed the turbogrid tutorial steps. But as I transfer the design to turbogrid ,I don't see the defined interfaces and walls of the secondary flow in the turbogrid geometry.
Can anyone help in this regard?
I have attached the design modeler and turbogrid screenshots.
mandar55patil is offline   Reply With Quote
secondary flow path, turbogrid
Axial Flow Pump Performance Prediction bharathn CFX 1 February 25, 2013 18:51
[Other] is free meshing or mapped meshing is best for flow problems shanu OpenFOAM Meshing & Mesh Conversion 0 February 18, 2010 12:56
Want to get secondary flow in 3D turbine rotor cascade darshak FLUENT 0 December 2, 2009 14:18
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 3, 1999 00:18
