April 21, 2022, 04:45 |
Wind Blade Serration Meshing Error
Chehade
Rep Power: 4 |
Hello, i am trying to simulate the 6DOF rotation of a serrated edge wind turbine, i have drawn my turbine on solidworks and imported to ANSYS. When i use watertight geometry i get an error at eh 'generate volume mesh' (i am using tetrahedral) that says there are gaps that must be filled or refinned. However, it highlights the serration which i purposely want to remain on my blades. Is there any way to fix without having to remove the serrations? Or at least modify their geometry. Kindly find below the serration pictures.
April 21, 2022, 11:46 |
Kira
Rep Power: 9 |
Imported into ANSYS what? That’s kind of like saying you made the part in CAD and need help with something software specific.
April 21, 2022, 11:50 |
Chehade
Rep Power: 4 |
Design modeler. The turbine is drawn in ansys design modeler then imported to solidworks for adding serration. Then re-imported to ansys design modeler for enclosures and boolean finally to mesh.
April 21, 2022, 11:51 |
Chehade
Rep Power: 4 |
I know ansys has problems with sharp edges but the whole point is having that sawtooth pattern so is there a workaround.
April 21, 2022, 11:54 |
Kira
Rep Power: 9 |
Have you seen this video? It’s from the ANSYS company
https://youtu.be/S_kpYzsqzo0 |
April 21, 2022, 11:58 |
Kira
Rep Power: 9 |
You can also try reducing the defeaturing tolerance, it should be less than the smallest details on your geometry.
April 21, 2022, 12:11 |
Chehade
Rep Power: 4 |
I have tried to repair but it states that it failed. As for the 2nd option i do not know how and where
April 22, 2022, 10:43 |
Chehade
Rep Power: 4 |
***Bump***
design modeler, error, mesh, serration, wind turbine |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 05:53 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 06:34 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 10:30 |
