Total mass in a closed domain is changing with time. |
April 20, 2022, 09:52 |
ABHINAV SINGH
Rep Power: 5 |
hello,
I am working with 2-D transient simulation with compressible flow, gravity assisted. I am using VOF- multiphase model and evaporation condensation model as the phase change model, with saturation temperature as a function of saturation pressure. liquiq is primary phase and Vapor is secondary phase. liquid properties - piece-wise polynomial function of temperature vapor density - Ideal gas vapor viscosity and thermal conductivity - piece-wise poly function of temperature. Operating pressure - 0, gauge pressure - 76043 Pa Operating density - 0 kg/m3 Initial temp - 75K CONVERGANCE criteria - (continuity - 1e-05), (velocity - 1e-04) and (energy - 1e-06) SOLUTION METHODS Pressure-velocity coupling - PISO Gradient - Least squares cell based Pressure - Body force weighted Density - second order upwind Momentum - Quick Volume fraction - geo-reconstruct Energy - first order upwind All the URFs are default. why is total mass changing with time and also the continuity residual falls in the range of 1e-01 to 1e+02? |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 10:10 |
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores | puneet336 | OpenFOAM Running, Solving & CFD | 11 | April 7, 2019 01:58 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Error in run Batch file | saba1366 | CFX | 4 | February 10, 2013 02:15 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
