April 18, 2022, 12:55 |
Wind Turbine 6DOF
Chehade
Rep Power: 4 |
Hi guys does anyone have a link for a Horizontal Wind Turbine 6DOf simulation tutorial on Ansys fluent with watertight geometry? I have found nothing when searching online and on youtube. My main issue is with the setup, dont really know how to correctly setup my 6DOF settings.
Thanks. |
April 18, 2022, 15:23 |
Kira
Rep Power: 9 |
What part of the setup are you specifically having issues with? Have you seen this thread: https://forum.ansys.com/discussion/3...vof-simulation It depends on which version of Fluent you are using. There is a video in that thread that may be helpful to you. |
April 18, 2022, 16:10 |
Chehade
Rep Power: 4 |
Basically im using watertight geometry and the generate volume mesh using tetrahedral method is not ending. Its stuck on refinning mesh for a very long time then fluent force closes. But i was told it is because the computer memory is used up and there is no more left for meshing (i have 16GB ram).
The part that i want to learn is that of 6DOF input in the setup, what angle of orientation to input, how to compute moment of inertia etc... |
April 18, 2022, 16:13 |
Chehade
Rep Power: 4 |
Btw i have another question. Lets say i made the min cell length 'X' and max cell length 'Y' when generating surface mesh. When i want to generate volume mesh must i also input the max cell mesh as 'Y' ? Or should it be higher or lower?
6DOF Savonius wind turbine problem? | ledinhanh | FLUENT | 1 | April 3, 2022 11:07 |
Wind Turbine simulation with air (6DOF) | zorkwan | FLUENT | 2 | July 11, 2018 05:24 |
Air Flow Analysis around a Wind Turbine | NightHawkRaven | FLUENT | 4 | August 12, 2014 18:18 |
Moving reference frame in wind turbine | kongl1986 | FLUENT | 0 | March 30, 2013 11:50 |
FSI - Wind Turbine | AUN | CFX | 13 | August 29, 2012 17:44 |
