April 15, 2022, 05:31 |
Interfaces and boundaries in Star CCM+
Boaz ruis
Hello everyone,
Im currently trying to investigate the effect of an air scoop on radiator flow performance for a car. However, i'm running stuck on inplementing the radiator/fan. I want to use a porous region as to simulate the pressure drop over the rad (i have already proved that this is an accurate representation) and a fan interface to simulate the fan. Right now i'm gettting stuck on defining the boundaries/regions/interfaces needed to get this to work. If i just draw a windtunnel over the rad it acts like it doens't exists in the simulation. However if i extract the radiator/parts from the windtunnel (in siemens nx, i dont quite understand how the extract geometry function works in star ccm) i get a lot of problems with interfaces/duplicate faces etc. Does anybody know how to do this effectively? I've added some pictures to clarify. Sincerely Boaz https://imgur.com/a/ilOWj4s this is the tunnel simply drawn around the radiator block https://imgur.com/a/I4sQNm4 a setup that does work, where the radiator is not fully encapsulated by the windtunnel, and a picture of the radiator/fan package i need to simulate |
Mesh generation: split boundaries in group of interfaces | Byba | Mesh Generation & Pre-Processing | 1 | May 28, 2019 16:11 |
[ANSYS Meshing] Mesh generation from Ansys: split boundaries in group of interfaces | Byba | ANSYS Meshing & Geometry | 3 | May 28, 2019 16:00 |
Error by creating interfaces for Multiple Regions – Heat Transfer | Sakuyalex | STAR-CCM+ | 3 | March 22, 2018 05:16 |
No flow through periodic (cyclic) boundaries in impeller with foam-extend-3.1 | anttiad9000 | OpenFOAM Running, Solving & CFD | 3 | March 2, 2016 20:37 |
2D Rotating Detonation Engine Periodic Boundaries | whitet86 | FLUENT | 2 | June 25, 2015 12:04 |
