April 14, 2022, 09:33 |
Set your own camera views on CFX Post
Brett
Rep Power: 14 |
Hi guys,
I've seen some posts on this but I didn't quite understand them, maybe I'm a touch slow on this. In any case I want to be able to set the camera angle manually but not using the mouse. For example I'd like to view an object from the positive Z axis with the Y axis pointing down and the X axis pointing to the right. Any thoughts? Brett |
April 14, 2022, 13:05 |
Kira
Rep Power: 9 |
Hello Brett,
I have attached a photo showing the view as requested. One small thing is you will have to view it from the - Z-axis rather than + Z-axis You will need to use your arrow keys. First, from the isometric view, click on the positive Z-axis. This will make your positive Y-axis point up and your X-axis point to the right. Then, using the up arrow key, press it until the letter Z is no longer visible and there is a dot at the corner of the coordinate axis. This way, you then know it is pointing straight out. Hope this helps. |
camera view, cfx & fluent, post procesing |
[ICEM] ICEM Scripting Issues | tylerplowright | ANSYS Meshing & Geometry | 33 | September 27, 2021 17:35 |
Pressure at inlet in post different to what I set? | Nineties123 | CFX | 3 | February 10, 2021 04:00 |
MassAve in CFX Post | Jens Trommer | ANSYS | 1 | December 5, 2019 18:39 |
Model scale down automatic in CFX Post. | aniketbajare | CFX | 5 | October 25, 2019 03:47 |
Star CCM+ to CFX Post | Sabal | Site Help, Feedback & Discussions | 0 | September 26, 2019 03:38 |
