Turbulent Heat Transfer Cavity flow
Old   July 29, 2000, 03:47
Default Turbulent Heat Transfer Cavity flow
Mehdi
Dear Sir I Was searching for Turbulent Heat Transfer Cavity Flow in 3-D with non-orthogonal walls.Is there any one who knows wether there is any paper or work on this field or not? Yours.. Mehdi
Old   July 31, 2000, 03:40
Default Re: Turbulent Heat Transfer Cavity flow
Istadi
Please find the following papers to get work about Turbulent Heat Transfer Cavity Flow in 3-D :
(1). Y.S. Tian, T.G. Karayiannis, Low Turbulence Natural Convection in An Air Filled squares Cavity. Part I. The Thermal and Fluid Flow Fields, Int. J. of Heat and Mass Transfer, vol. 43, 2000, pp.849-866. (2). Y.S. Tian, T.G. Karayiannis, Low Turbulence Natural Convection in An Air Filled squares Cavity. Part II. The Turbulence Quantities, Int. J. of Heat and Mass Transfer, vol. 43, 2000, pp.867-884.
and the following paper may be help also: (1). Wei-Mon-Yuan, Hung-Yi-Li, and David Lin, Mixed Convection Heat Transfer in A Radially Rotating Square Duct with Radiation Effects, Int. J. of Heat and Mass Transfer, vol. 42, 1999, pp.35-47.
Thanks,
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Turbulent Heat Transfer Transport Equation Flo.duck Main CFD Forum 0 May 6, 2009 04:37
Turbulent heat transfer Hugo FLUENT 2 January 11, 2007 10:34
axial flow around a cylinder -heat transfer model? Ralf Schmidt Main CFD Forum 1 March 21, 2006 09:54
heat transfer in rectangular cavity.....HELP!!!... srinath t k FLUENT 1 December 12, 2000 01:43
