How to couple two cell zones which have a common interface
Old   April 8, 2022, 23:28
Default How to couple two cell zones which have a common interface
Vivek MJ
vivjk94 is on a distinguished road
I have two 3-D rotating fluid circular zones both adjacent to one another. I am trying to do a moving reference frame motion where i need to add rotation to one zone and the other zone must rotate simultaneously due to coupling. So for the driving circular zone, i enabled frame motion, set motion to rotation and gave a certain rpm. Now what do i need to do for the adjacent fluid zone so that it rotates at a similar rpm to the driving zone?
Both zones are same fluid-water and share a mesh interface
Kindly help
Thanks in advance
vivjk94 is offline   Reply With Quote
Old   April 10, 2022, 23:53
Vivek MJ
Help please
Old   April 11, 2022, 00:55
Kira
aero_head is on a distinguished road
What program are you using for this?
aero_head is offline   Reply With Quote
Old   April 11, 2022, 02:23
Vivek MJ
I am using Fluent
fluent, moving reference frame, rotating body
UDF in case with DPM modle POSTHU Fluent UDF and Scheme Programming 0 March 3, 2021 08:21
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
unassigned interface zone warning in FLUENT hapsari devi FLUENT 26 December 11, 2017 07:28
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
