Turbogrid Negative Volume Error
Old   March 31, 2022, 07:55
Default Turbogrid Negative Volume Error
aeb
ata
aeb is on a distinguished road
Hello everyone,
I've designed different axial fans on CFTurbo via ANSYS Workbench. It is my first time on this and i am not an expert.
I have axial fans with 8 blades or 6 blades. After i design fans, i apply mesh on Turbogrid for only single blade passage via Workbench. Unfortunately, when i decrease axial fan's number of blades such as form 8 to 4 or from 6 to 3, i get Negative Volume errors in Turbogrid. I've tried to change so many setups on Turbogrid and added more layers between hub and shroud but i could not solve the problem. For 8 or 6 number of blades i am not getting this error.
I searched lots of post on internet but i could not find a solution. I can not fix the problem and not move on my analysis for a month because i have no experience on CFTurbo and Turbogrid before.
Thanks in advance for answers.
aeb is offline   Reply With Quote
cfturbo, turbogrid
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
