Angled Airfoil Geometry Problem
Old   March 29, 2022, 16:05
Default Angled Airfoil Geometry Problem
Justin
pharva is on a distinguished road
I'm trying to create a structured mesh for an angled NACA 0012 airfoil. It's very close to being right except for a very tiny issue that is causing large problems in Fluent.
I've imported a closed coordinate file for the airfoil (attached) and use "Surface from Edge" function to create my airfoil surface body. When I do that, the surface body creates a rounded trailing edge instead of a sharp point. I then create my fluid body boundaries and create a boolean>subtract to subtract the fluid body from the airfoil body. I then use the split edge function to split the airfoil in half. Then create a construction Point by selecting the fluid body and the two edges as guides. Instead of creating a point where the two edges meet (the exact trailing edge tip shown in Problem 2 attached image) it creates a point that is a bit offset (Problem attached image). Because of this, I can't create a vertical projection line that is at the exact tip of the airfoil.
Any guidance is appreciated.
pharva is offline   Reply With Quote
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE mariachi ANSYS Meshing & Geometry 5 May 30, 2018 03:52
[ICEM] Problem Meshing Asymmetrical Geometry Madhatter92 ANSYS Meshing & Geometry 1 December 23, 2017 06:56
Problem with building geometry - concentric cylinders Rhoddwen OpenFOAM Pre-Processing 9 December 17, 2014 11:02
(AutoGRID 5) Problem in Geometry definition of propeller venkat_aero2007 Fidelity CFD 14 July 31, 2012 15:05
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
