How to run Mixture multiphase model for Hydrocyclone |
March 23, 2022, 10:36 |
P Arjun kumar
Rep Power: 12 |
Hi All,
I am currently trying to solve a mixture multiphase simulation for hydrocyclone to capture the effect of high solid content in the flow medium.(Generally, it is advised to perform Lagrangian simulation for solids content >10%) So I have started mixture multiphase model. But what I observe is pressure is not developing inside the hydrocylone so air-core formation is not happening. But if perform VOF simulation with water and air phases(Excluding solid phase) I can clearly see air-core formation. I request you to kindly through some light on where I might go wrong. Turbulence: RSM Looking forward to hear some valuables suggestions from you all. Thanks and Regards, Arjun |
hydrocylone, mixture multiphase model, multiphase modelling, rsm, vof model |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 19:19 |
Multiphase Mixture Model and limits | Brandt_germany97 | Main CFD Forum | 0 | August 20, 2018 09:08 |
The problem of Stiff Chemistry Solver in Multiphase model | shenzhou1987 | FLUENT | 1 | January 11, 2016 03:52 |
mixture model or multiphase model in my UDF? | aleisia | Fluent UDF and Scheme Programming | 0 | June 8, 2011 14:25 |
MULTIPHASE - FREE SURFACE & MIXTURE MODEL | Aris | FLUENT | 3 | April 28, 2009 12:46 |
