When is the wake considered to have 'died out'? |
March 17, 2022, 11:23 |
Varun V P
Rep Power: 6 |
What is meant when it is said that the wake should die out before reaching the pressure outlet?
I have the steady state simulation of a propeller, and in the contour plot of the velocity magnitudes you can see that at the pressure outlet there is still a 'jet' of slightly higher velocity than ambient. Should this be exactly 0 throughout the pressure outlet boundary condition surface? Also, looking at the streamlines, what do we expect when the wake 'dies out'? Should they terminate collectively at a place where the velocity contours are zero? |
domain extents, propellers, wake modeling |
wind turbine wake issue | vagge | OpenFOAM Running, Solving & CFD | 6 | October 11, 2016 07:45 |
Wake length behind a circular cylinder | Corleone84 | STAR-CCM+ | 6 | December 31, 2015 01:10 |
having problems with implementing the wake rollup for a panel method | smilesgiles89 | Main CFD Forum | 0 | August 6, 2015 20:09 |
having some issues in Wake Stability using UVLM for propellers | jackgeo | Main CFD Forum | 1 | November 26, 2014 05:05 |
Cylinder Wake calculation | Adam Chapman | Main CFD Forum | 1 | January 30, 2007 12:54 |
