Computing Cross-Correlation Matrix, and multiplying Result by Correlated Vars |
March 16, 2022, 22:47 |
Rep Power: 4 |
Hello friends,
March 17, 2022, 14:07 |
Lucky
Rep Power: 66 |
I simply don't understand what you are trying to calculate in 1) to contribute towards 1-3.
4) xcorr2 does perform correlation in both directions of the matrix. But I'm not sure if this gives you what you want in 1). If your data was arranged in two spatial dimensions, xcorr2 would give you the two-dimensional spatial correlation function. If your data is arranged in space-time, it gives you a spatial correlation and and a temporal correlation. But is this what you want? 5). A pair of 3-element vectors has 5 possible shifts. -2,-1,0,+1, and +2. The generalized cross-correlation therefore is a 5-element vector. What length were you expecting? If you do not permit zero padding and expected a single scalar output, then the element in the middle of the output contains the zero shift. +3, -3, and greater shifts would result in either a periodic shift or a null output depending on your definition of cross-correlation. In either case, there is no output needed for shifts exceeding -2 or +2 and so the output is no more than a 5 element vector. |
March 17, 2022, 14:19 |
Rep Power: 4 |
I stumbled across a book, "Particle Image Velocimetry: a Practical Guide" after posting this question, which clarified everything (in the Chapter 5: Image Evaluation Methods for PIV)
correlations, turbulence analysis |
