Should prop wake dissipate before reaching outlet domain? (Transient))
Old   March 8, 2022, 01:19
Default Should prop wake dissipate before reaching outlet domain? (Transient))
Varun V P
VarunV is on a distinguished road
We are simulating some test cases for a propeller, which requires that we do a transient simulation. The common advice on sizing of the mesh is that the pressure outlet should be far enough so that the wake dies out before it reaches it. But since this is a transient simulation, it takes a lot of time steps for the wake to fully reach the outlet. And even when it is doing so, I notice on my lift and drag monitors that the forces are converged. Therefore, I was thinking if I should run a steady state simulation first, wait for wake to fully develop, and then switch to transient?
VarunV is offline   Reply With Quote
Old   March 8, 2022, 05:16
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Well, it depends on what you really want to simulate. Let me clarify:
1) you want to simulate the whole transient, that is the flow problem starting from some suitable physical initial and boundary conditions.
2) you are interested only in the final fully developed unsteady flow when an equilibrium is reached.
Clearly, only case 2 can be started from arbitrary initial conditions and you can use a converged steady solution.
Be aware that, depending on the formulation you are using (DNS/LES/DES/URANS) the things can be more complex.
FMDenaro is offline   Reply With Quote
Old   March 8, 2022, 08:57
Varun V P
I want to simulate the forces acting on the propeller when it is exposed to oblique flow. Barring the initial wake development, I would be interested in the force variation as the blades go through a complete revolution. So I guess case 2 is what I'm looking for.
So when I go with case 2, if I understand correctly, the steady state simulation will converge with a full wake, which the transient simulation will finally refine. Am I correct?
propellers, transient 3d, wake modeling
Calculating fluid recirculation at an outlet in transient analysis HeatK CFX 3 November 4, 2020 15:33
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 09:07
OUTLET in domain billow Phoenics 1 April 10, 2006 05:11
