Navier-Stokes equation in spherical coordinate
Like Tree1Likes
Old   July 28, 2022, 11:16
optimux's Avatar
Mingming Zhang
optimux is on a distinguished road
Originally Posted by unogamerules View Post
Yes, I derived continuity equation by myself from mass conservation, but failed for the momentum equations. There must be something missing that I have to dig into.
You have to first derive all operators in spherical coordinates and apply them onto field variables. Then you may have a chance.
optimux is offline   Reply With Quote
Old   August 3, 2022, 07:32
Pierre
Slyphlamen is on a distinguished road
Had some identical trouble when dealing with my model, where I use compressible Euler; but I think for NS equations you'll find more litterature than on specifically Euler.
A nice place if you derive everything yourself https://mathworld.wolfram.com/SphericalCoordinates.html ; but you can definitely find the NS given in an article (although you might find continuity, momentum, and energy es given separatly as they are long to write). From a quick search typically I found this https://www.google.com/url?sa=t&rct=...zL_IF0JoBM-8wK
Physically speaking, moving from Cartesian to curvilinear geometries (such as spherical coordinates) adds a curvature term to your equations from what I understood (at least in the compressible Euler case; but I wouldn't be surprised if this can be extended to NS).
Slyphlamen is offline   Reply With Quote
Old   August 3, 2022, 09:54
optimux's Avatar
Mingming Zhang
Yeah, that MMA page is pretty useful. Thank you so much.
Old   August 3, 2022, 11:08
Pierre
Another cool article that helped me a lot understand how things worked is the first article of the Zeus-2D code. For you specifically you might want to check Appendix A of https://ui.adsabs.harvard.edu/abs/1992ApJS...80..753S
The code is in Fortran but it's avalaible online https://www.astro.princeton.edu/~jstone/zeus.html
Again this is for compressible Euler and not NS; but there are many similarities obviously.
Old   August 3, 2022, 12:05
optimux's Avatar
Mingming Zhang
Also, a paper from Santelli, Luca "A finite–difference scheme for three–dimensional incompressible flows in spherical coordinates" is helpful. Now I'm using spectral method for High Ra number (of course incompressible flow). Thank you so much for your papers and codes.
Cheers!
Slyphlamen likes this.
ns equation, spherical coordinate
Line term in the Navier - Stokes equation. vgoy OpenFOAM Programming & Development 2 October 26, 2021 10:07
Navier Stokes Equation for Non-newtonian fluid? shivasluzz Main CFD Forum 6 June 9, 2015 11:44
need 2d equation for navier stokes in c sudeep FLUENT 1 February 16, 2011 18:01
Navier stokes compresible viscid flow fea, somebody can help? Jose Choy Main CFD Forum 3 October 24, 2003 03:28
help: I am trying to solve Navier Stokes compressible and viscid flow Jose Choy Main CFD Forum 2 May 18, 2000 06:45
