Defining inlet velocity in moving referance frame (MRF) |
February 14, 2022, 05:55 |
Halit Guvenc
Rep Power: 4 |
Hi everybody,
I want to ask that when the calculate blade rotation with steady state moving referance frame method, every body gives a velocity to inlet include guides. But I want to do that a fan which rotates in the still-air and has a nozzle around the blade. I give the boundary conditions velocity inlet '0' m/s, pressure outlet atmosphere. All surrounding defined by symmetry. I do some simulations, when the blade was alone, the region is circular around the blade (image 2), just reversed flow on the outlet. But when the nozzle comes I choose the rotating region inside the nozzle and the result seems to wrong.(image 3,4) I search a little bit how it is done correctly and a little bit confused, how can I define the inlet velocity and what is need to be rotating region? |
VOF Volume fraction in Velocity inlet | aruelle | FLUENT | 2 | May 10, 2024 10:17 |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 10:34 |
[GAMBIT] defining velocity inlet boundary in gambit | flow_CH | ANSYS Meshing & Geometry | 2 | June 3, 2013 01:28 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
