February 3, 2022, 11:52 |
Error in interface pressure jump condition
Cao Văn Long
Hi everybody, I hope that you are doing well.
I am developing a two-phase solver with the CLSVOF method, my CLSVOF validation cases run well. However, there are some errors when I tried combining the method with an N-S solver. I run a static drop simulation to test the interface jump condition, but as you can see in the attached images, the result became unstable. The first photo is from timestep 3, and the second one is from timestep 4. After that, the pressure value became larger and larger, finally got NaN. I use the CSF method to consider surface tension force. Have you ever encountered the problem and do you have any idea why the problem occurs? Thank you all for reading!!! |
Time dependant pressure boundary condition | yosuke1984 | OpenFOAM Verification & Validation | 3 | May 6, 2015 07:16 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Pressure jump and momentum source | Tanya | FLUENT | 1 | June 4, 2009 16:22 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
