How to call mDot used in different header file?
Old   January 27, 2022, 03:06
Default How to call mDot used in different header file?
hari charan
saicharan662000@gmail.com is on a distinguished road
I need to call mDot used in twophasemixtureThermo.H and twophasemixtureThermo.C file in PEqn.H file. I ran the twoPhaseMixtureThermo . it didnt give any error.But when I ran solver I got above error.I am attaching the files below. Can anyone help me?
-lm -o /home/hari/OpenFOAM/hari-8/platforms/linux64GccDPInt32Opt/bin/myCompressibleInterFoam /usr/bin/ld.bfd: Make/linux64GccDPInt32Opt/myCompressibleInterFoam.o: in function `main': myCompressibleInterFoam.C.text.startup+0x1396): undefined reference to `Foam::twoPhaseMixtureThermo::mDot() const' /usr/bin/ld.bfd: myCompressibleInterFoam.C.text.startup+0x3728): undefined reference to `Foam::twoPhaseMixtureThermo::mDot() const' /usr/bin/ld.bfd: myCompressibleInterFoam.C.text.startup+0xb4cf): undefined reference to `Foam::twoPhaseMixtureThermo::mDot() const' collect2: error: ld returned 1 exit status make: *** [/opt/openfoam8/wmake/makefiles/general:142: /home/hari/OpenFOAM/hari-8/platforms/linux64GccDPInt32Opt/bin/myCompressibleInterFoam] Error 1
twoPhaseMixtureThermo.H
class twoPhaseMixtureThermo
public psiThermo,
public twoPhaseMixture,
public interfaceProperties
public:
// Private Data
//- Thermo-package of phase 1
autoPtr<rhoThermo> thermo1_;
//- Thermo-package of phase 2
autoPtr<rhoThermo> thermo2_;
//ADDED
dimensionedScalar lambdaF_; // thermal conductivity [kg*m/s3/K]
dimensionedScalar Tsat_; // saturation temp [K]
dimensionedScalar Tinf_; // bulk temperature of the water [K]
dimensionedScalar ifg_; // latent heat for for fluid [m2/s2]
dimensionedScalar charLength_; //characteristic length
dimensionedScalar g_; // gravity
dimensionedScalar mcCoeff_; // mass condensation coefficient for better view
// interface area function
tmp<volScalarField>interfaceArea() const; // interfacial area [m2]
// heat transfer coefficient
tmp<volScalarField> hCoeff() const; // heat transfer coefficient missing division by (Tsat_-Tinf)^(1/5)
tmp<volScalarField> mDot() const;
twoPhaseMixtureThermo.C
#include "twoPhaseMixtureThermo.H"
#include "gradientEnergyFvPatchScalarField.H"
#include "mixedEnergyFvPatchScalarField.H"
#include "collatedFileOperation.H"
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
namespace Foam
defineTypeNameAndDebug(twoPhaseMixtureThermo, 0);
// * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * //
Foam::twoPhaseMixtureThermo::twoPhaseMixtureThermo
const volVectorField& U,
const surfaceScalarField& phi
psiThermo(U.mesh(), word::null),
twoPhaseMixture(U.mesh(), *this),
interfaceProperties(alpha1(), U, *this),
thermo1_(nullptr),
thermo2_(nullptr),
lambdaF_("lambdaF", dimMass*dimLength/(dimTime*dimTime*dimTime*dimTemperature) , lookup("lambdaF")),
Tsat_("Tsat",dimTemperature, lookup("Tsat")),
Tinf_("Tinf",dimTemperature, lookup("Tinf")),
ifg_("ifg", dimLength*dimLength/(dimTime*dimTime),lookup("ifg")),
charLength_("charLength", dimLength, lookup("charLength")),
g_("gravity", dimLength/(dimTime*dimTime) ,lookup("gravity")),
mcCoeff_( (Tsat_-Tinf_) / ifg_ )
volScalarField T1
IOobject
IOobject::groupName("T", phase1Name()),
U.mesh().time().timeName(),
U.mesh()
T_,
calculatedFvPatchScalarField::typeName
T1.write();
volScalarField T2
IOobject
IOobject::groupName("T", phase2Name()),
U.mesh()
T_,
T2.write();
// Note: we're writing files to be read in immediately afterwards.
// Avoid any thread-writing problems.
fileHandler().flush();
thermo1_ = rhoThermo::New(U.mesh(), phase1Name());
thermo2_ = rhoThermo::New(U.mesh(), phase2Name());
// thermo1_->validate(phase1Name(), "e");
// thermo2_->validate(phase2Name(), "e");
correct();
// * * * * * * * * * * * * * * * * Destructor * * * * * * * * * * * * * * * //
Foam::twoPhaseMixtureThermo::~twoPhaseMixtureTherm o()
// * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * * //
Foam::tmp<Foam::volScalarField>
Foam::twoPhaseMixtureThermo::interfaceArea() const
// return the interfacial area based on model for interfacial area
// returns dimensions Area
// model based on regular volume cells, taking the largest cut area
// as maximum for area, linear increase and decrease with alpha
const volScalarField& cellVolume =
alpha1().db().lookupObject<volScalarField>("cellVo lu");
volScalarField limitedAlpha1 = min(max(alpha1(), scalar(0)), scalar(1));
const dimensionedScalar
areaFactor("areaFactor",dimensionSet(0,2,0,0,0,0,0 ), 0.0);
volScalarField interfaceArea = alpha1() * areaFactor;
volScalarField maxArea = alpha1() * areaFactor;
maxArea = sqrt(3.0)*pow(cellVolume,(2.0/3.0));
return tmp<volScalarField>
(neg(limitedAlpha1-0.5)*maxArea*2.0*limitedAlpha1) +
(pos(limitedAlpha1-0.5)*maxArea*(-2.0*( limitedAlpha1 - 1.0)))
//ADDED
Foam::twoPhaseMixtureThermo::hCoeff() const
// from [Bejan, Convection heat transfer, 1995]
return
1.079 * (lambdaF_ / charLength_ ) * pow(
(pow3(charLength_) * ifg_ * g_ * (thermo1_->rho()-thermo2_->rho()) ) /
(lambdaF_ * nu() * (Tsat_ - Tinf_) ) , 0.2 )
//ADDED
Foam::twoPhaseMixtureThermo::mDotAlphal() const
// return dimensions [kg/m3/s]
// return condensation divided by (1-alpha)
volScalarField interfaceArea = this->interfaceArea();
volScalarField hCoeff = this->hCoeff();
Info << "Max interFaceArea: " << max(interfaceArea).value() << " m2" <<endl;
Info << "Max Heat transfer coefficient: " << max(hCoeff).value() << " W/m2/K" << endl;
(hCoeff * mcCoeff_ * interfaceArea)
//ADDED
zeroFactor("zeroFactor",dimensionSet(0,0,0,0,0,0,0 ), 0.0);
volScalarField mDot = mDotAlphal() * zeroFactor;
mDotAlphal() * 1
PEqn.H
// Cache p_rgh prior to solve for density update
volScalarField p_rgh_0(p_rgh);
//ADDED
const volScalarField& mDot = mixture.mDot();
while (pimple.correctNonOrthogonal())
fvScalarMatrix p_rghEqnIncomp
fvc::div(phiHbyA)
- fvm::laplacian(rAUf, p_rgh)
- (mDot/rho1)
+ (mDot/rho2) //mDot here should be computed from twoPhaseMixtureThermo
solve
p_rghEqnComp1() + p_rghEqnComp2() + p_rghEqnIncomp
saicharan662000@gmail.com is offline   Reply With Quote
compressibleinterfoam, interfoam, openfoam, openfoam 8
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
