January 24, 2022, 10:53 |
Acoustic propagator
Federico Nahuel Ramírez
Rep Power: 5 |
I am currently modeling a UAV propeller using OpenFOAM v1912. My goal is to perform an aeroacoustic study. So far I have used libAcoustics to obtain noise values by applying Ffowcs Williams Hawkings and I have a model that seems to match the experimental values. I would like to take the study further, and for this I had thought of using the results of the simulations to study how the noise due to the propeller would propagate in a real environment. Does anyone know any code that could serve me for this purpose? I am trying to work with open source software, but if there is any interesting commercial alternative it could be considered. Looking around I have found a code called code_Tympan, but I can't find any resources besides the github code that I have not been able to get working. I have also been mentioned the kraken code, but as far as I have found it is intended for marine acoustics, so I interpret that it is not applicable to this case. Any ideas would be of great help. Thank you very much! |
January 24, 2022, 13:00 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
Have you considered that any solver able to solve the unsteady compressible flow formulation provide all you need for acoustic in the pressure field? Why do not still use OpenFOAM ? |
January 25, 2022, 04:38 |
#3 | |
Rep Power: 5 |
In addition, I would have to solve them on a very refined mesh to avoid filtering the high frequencies, which would make it impossible to extend the study to large domains. That's why I'm looking for a way to propagate the acoustic perturbations that are calculated with OpenFOAM. |
Acoustic Power Discrepancy | Time4Tea | FLUENT | 0 | August 21, 2018 10:46 |
Vibro-acoustic using Ansys Workbench with Acoustic extension | Anupyemme | Structural Mechanics | 0 | June 19, 2018 08:06 |
method about getting the acoustic natural frequency. | myjesus123@empal.com | FLUENT | 3 | April 17, 2017 10:12 |
Acoustic basics in Star CCM+ | samsakcz | STAR-CCM+ | 0 | October 24, 2016 08:17 |
Acoustic pressure contour | kozden | FLUENT | 0 | July 20, 2013 06:34 |
