Error: Update-Dynamic-Mesh failed. Negative cell volume detected. |
January 23, 2022, 10:32 |
PG
I simulate a Check Valve 2D using a Dynamic Mesh. I followed step by step this tutorial: https://www.youtube.com/watch?v=NTp7LfVVLks But I had this error: Update-Dynamic-Mesh failed. Negative cell volume detected. I choosed a mesh with a rectangular elements and maximum dimension of 0.0005 m. I set manually the 1DOF properties (not using UDF File). I choosed Mesh Layering test method After the error I tried to reduce elements size (near the moving part of the valve), then I reduced the time step, finally I change shape elements from rectangular to triangular, without any benefit. How can I do? Cattura.JPG Cattura2.JPG |
Negative cell volume detected, dynamic mesh | tony25800 | FLUENT | 6 | September 17, 2014 20:50 |
Dynamic Mesh failed. Negative Cell Volume Detected | Sufyan Abushaala | Main CFD Forum | 0 | August 27, 2014 05:51 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
