January 20, 2022, 05:49 |
Viscous layers SALOME
Rep Power: 4 |
Hi guys!
I'm a new user so I hope I'm doing it right. I'm trying to create a mesh for a flow around turbin blades to export in OpenFOAM, but I'm expiriencing some problems. I created the geometry by extruding the bottom surface. If I mesh it with no boundary layers I have no problem , but when I add the hypothesis it doesn't work (hypothesis are on the top and botton surfaces, on the central blade and on the two lateral blades). I guess it's because the little triangles that create at the bottom and at the top of the rear-left surface(the blue one). Does someone of you know how i can fix it? Unfortunately I can't share the python script. |
January 21, 2022, 02:13 |
Rep Power: 16 |
What type of problems do you experience in OpenFOAM? Is it at the checkMesh stage or is it during the simulation?
January 21, 2022, 18:29 |
Rep Power: 4 |
Thank you for replying me. This is what I get from OpenFOAM during the mesh generation. The blue face is what I called "Fluido_anteriore_sinistro", and it is considered as faceZone.
2D viscous layer in Salome. (Flat plate simulation) | Akin-iii | Mesh Generation & Pre-Processing | 0 | July 25, 2021 09:52 |
Salome Viscous Layers | ancolli | OpenFOAM Pre-Processing | 8 | March 16, 2021 04:56 |
Viscous layers in Salome 9.3.0 | OskarT | Main CFD Forum | 0 | September 10, 2019 11:49 |
Residuals and forces spiraling out of control before failing | edomalley1 | OpenFOAM Running, Solving & CFD | 3 | September 7, 2018 11:42 |
Viscous Layers generating defaultFaces | NoradFirst2 | OpenFOAM Pre-Processing | 4 | June 21, 2018 06:49 |
