Aeroacoustic - filtered dB map analysis
Old   January 19, 2022, 03:54
Post Aeroacoustic - filtered dB map analysis
Lukas Richter
wilder_pinguin is on a distinguished road
Hey,
I'm currently working in the field of Aeroacoustics and will do some investigation on a radial fan soon. I would like to display the sound pressure on the surface of my geometry. To add an additional value for the analysis of sound sources I would like to establish a kind of "BandFilter" which excludes the generation of sound pressure which isn't part of the chosen band, meaning just to include frequencies in the investigation which are part of the band.
I found this paper published by Rebecca Schäfer in 2020 -> https://www.mdpi.com/2624-599X/2/4/40/htm . The post processing step I'm looking forward to do is shown in figure 16 and 17. The researcher did this by using intern functionalities of "Poweracoustics" by Dassault Systemes, which I am not able to use.
My question is, is there any way to reproduce this post processing scheme in Matlab ? Do you know some keywords to search or publications governing this topic?
Would be a pleasure if anybody could help out.
Greets and Thank you
wilder_pinguin is offline   Reply With Quote
aeroacoustics, db_map, filtered
How to implement a sensitivity analysis for certain items Mason liu CFX 10 August 17, 2017 09:46
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload ingjuanm90 ANSYS 0 July 26, 2016 15:04
Analysis of rotating fan in room in ansys fluent harianshu FLUENT 0 April 10, 2016 15:01
Lateral Analysis Centrifugal Pump laltenburg ANSYS 0 January 11, 2016 09:54
Is CFD Science or Art ? John C. Chien Main CFD Forum 36 October 5, 1999 13:58
