Correlation, energy spectrum and integral length scale
Like Tree2Likes
Old   December 14, 2021, 23:23
Unhappy Correlation, energy spectrum and integral length scale
TurbJet is on a distinguished road
In homogeneous isotropic turbulence (HIT), the correlation function
R_{ij}(\pmb{r}) = \overline{u_i(\pmb{x})u_j(\pmb{x}')}
and the energy spectrum tensor
\Phi_{ij}(\pmb{k}) = \overline{\hat{u}_i(\pmb{k})\hat{u}_j^*(\pmb{k})}
are a Fourier-transform pair, i.e.,
\Phi_{ij}(\pmb{k}) = \frac{1}{(2\pi)^3}\int R_{ij}(\pmb{r})e^{-i\pmb{kr}}d\pmb{r}\;,\;
R_{ij}(\pmb{r}) = \int \Phi_{ij}(\pmb{k})e^{i\pmb{kr}}d\pmb{r}
where \pmb{r} = \pmb{x}-\pmb{x}', \pmb{u}' = \pmb{U}-\bar{\pmb{U}} is the fluctuating part, and \overline{(\cdot)} represents the averaging. Additionally, the longitudinal integral length scale is defined as
\mathcal{L}_{11} = \int_0^{+\infty}\mathcal{R}_{11}(r_1)dr_1
where \mathcal{R}_{11} is the correlation coefficient in the longitudinal direction.
Combine all these, one can derive the integral length scale from the one-dimensional spectrum
\Phi_{11}(k_1 = 0) = \frac{1}{2\pi}\int R_{11}(r_1)dr_1 = \frac{1}{2\pi}\cdot 2\overline{u_1^2}\mathcal{L}
thus giving
\mathcal{L}_{11} = \pi\frac{\Phi_{11}(k_1=0)}{\overline{u_1^2}}
However, for HIT, \Phi_{11}(k_1=0) is expected to be zero, given that the zeroth mode (k=0) for velocity should be zero mean. Hence, from above, the integral length scale will be zero as well. This doesn't seem right to me. So could anybody point out where am I missing?
Thanks.
TurbJet is offline   Reply With Quote
Old   December 15, 2021, 04:58
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Your case represents a full periodic box, in such a case the characteristic scales is the Taylor microscale. Clearly, while considering only fluctuations, there is no meaning in a characteristic lenght scale for the “large” structures.
PENGGEGE777 likes this.
FMDenaro is offline   Reply With Quote
Old   December 15, 2021, 13:08
Ok, let's forget about turbulence and the physical background, and consider more generic case. Let's consider a 1-D signal. Here is a zero-mean periodic brown noise on the interval [0,2\pi]
Clearly, it is long-range correlated, and we can extend the concept above and define an integral length scale for this signal. However, from the math I showed, the integral length scale is determined by the mean (i.e., the k=0 mode), which will be zero in this case. This still doesn't make sense.
Old   December 15, 2021, 13:25
In isotropic homogeneous turbulence, the integral length scale is defined as the weighted average of the inverse wavenumber, i.e.,
where is the energy spectrum.
Have also a look to this paper
https://www.researchgate.net/publica...Numerical_Data
Old   December 15, 2021, 13:52
Lucky
The velocity fluctuation signal u' has zero Fourier coefficient.
The energy spectrum is the Fourier transform of the correlation function (more technically the two-point correlation function) which is non-zero if there is any correlation. And as you say, clearly it is (long-range) correlated. Unless the signal is a trivial (zero everywhere all the time) then it will almost certainly have a finite correlation.
Old   December 15, 2021, 15:25
Yes, I've seen this definition. But I don't see where I made a mistake in my derivation.
Same result is shown in Eq.4.11 in here, even though it's in time.
Old   December 15, 2021, 15:27
Yes, I agree. But I fail to see where I made a mistake in my derivation.
Old   December 15, 2021, 15:39
Lucky
If you subtract the DC part of a signal (or use any signal with zero mean), you get that the energy spectrum is 0 corresponding to a mean of 0. It says nothing about the length scale.
That is, phi is zero and u bar is zero. Any length scale satisfies that.
Old   December 15, 2021, 15:57
Excuse me but I don't quite understand. Could you elaborate?
Take the 1-D signal I mentioned in one of the reply above for example. It's a periodic signal with zero mean, and clearly, \Phi(k=0) = 0. By extending the derivation above,
\Phi(k=0) = \frac{\overline{u^2}}{\pi}\mathcal{L} \rightarrow \mathcal{L} = 0
Old   December 15, 2021, 16:19
Something in your formula makes me think about an ideal case: imagine a total random signal, that is a white spectrum. It is uncorrelated, you will see the separation point ->0. And the formula seems to become an identity like 0=0*0 ...But, on the other hand, a small correlation would produce the RHS to be non vanishing.
Old   December 15, 2021, 17:23
Lucky
If your signal has zero mean then u bar is zero.
And phi is zero like you say. This does not imply that L is zero. If you re-arrange the formula for L then you make the division by 0 mistake.
I think what you are forgetting is that u bar is zero.
Old   December 15, 2021, 17:27
\Phi(k=0) = \frac{0}{\pi}\mathcal{L}
\mathcal{L}_{11} = \pi\frac{\Phi_{11}(k_1=0)}{\overline{u_1^2}} = \frac{0}{0}
Well, be careful, his formula has (u^2)_bar= (u'^2)_bar.
Old   December 15, 2021, 18:16
Lucky
Let me just take a step back and ask from where do we get \Phi_{11}(k_1 = 0) = 0
And what kinds of signals are we talking about? Their properties cannot be ignored. White noise is uncorrelated. Brown noise has a flat non-zero power spectral density. Arbitrary but otherwise statistically stationary signals have correlation.
Old   December 15, 2021, 19:02
Yes, I agree. But the math I showed doesn't seem this way.
Old   December 15, 2021, 19:03
In the example above, I used a brown noise. And I believe brown noise has energy spectrum E(k)\propto k^{-2}, not a flat one; flat one is for white noise.
Old   December 15, 2021, 19:04
Well, the denominator is \overline{u^2}, the u here is the fluctuating part, i.e., u = U-\bar{U}, as I already indicated in the post; indeed, \bar{U} = 0. Anyway, I don't think the denominator will be zero.
And for why \Phi(k=0) = 0. Recall that I consider a 1-D zero-mean brown noise above, and in 1-D the energy spectrum is
\Phi(k) = \hat{u}(k)\hat{u}^*(k)
in which \hat{u}(k) is the Fourier transform of the fluctuating part u(x) = U(x) - \bar{U}(x). Since the noise is zero mean, \hat{u}(k=0) = 0, and so \Phi(k=0) = \hat{u}(k=0)\hat{u}^*(k=0) = 0.
Old   December 15, 2021, 21:14
Lucky
You're right. Brown noise is the integral of white noise. The power spectral density for white noise is a constant. The power spectrum for brown noise goes like 1/f^2 or 1/k^2 since we're talking about space. Either way, neither are identically zero.
The Fourier transform of a constant is not 0.
Old   December 15, 2021, 21:40
What constant are you referring to?
For a zero-mean signal, isn't the zeroth-mode (or the DC component) \hat{u}(k=0)=0? Then the spectrum \Phi(k=0) = \hat{u}(k=0)\hat{u}^*(k=0) = 0?
Old   December 15, 2021, 22:08
Lucky
You're probably thinking that \hat{u} is the thingy you see when you plot an FFT or the amplitude when you look at a Fourier plot. That's only the real part of the complex Fourier representation. There is also an imaginary part.
If consider a constant signal with non-zero mean, a simple DC signal, the Fourier transform of a constant DC signal is a Dirac delta function. The special case of the constant being 0 has very peculiar properties. Basically, \hat{u} ain't 0.
Eifoehn4 likes this.
Old   December 16, 2021, 19:01
This doesn't make sense to me. For a real-value signal, the zero mode has to be real as well, and its value is equal to the mean of the signal. I am not talking about a constant signal here, I am talking about a signal with zero mean.
correlation, integral length scale, velocity spectrum
help Energy spectrum 2.0 bhigahAshish Main CFD Forum 7 July 14, 2019 06:20
Energy spectrum in frequency bhigahAshish Main CFD Forum 4 July 7, 2019 11:54
From the correlation tensor Rii to the three-dimensional spectrum E(k). lucamirtanini Main CFD Forum 4 January 30, 2019 12:28
Integral Length Scale - 2D WhiteShadow Main CFD Forum 5 May 19, 2018 17:56
von Karman curve fitting to field measured spectrum doutormanel Main CFD Forum 0 October 18, 2012 10:02
