Using solved simulation as an initial flow field? |
Halit Guvenc
Rep Power: 4 ![]() |
Hello everyone,
I am doing a formula type car external flow simulation and changing just one part between simulations. I really want to know if i just remove the changed part and remesh, then solve with previous simulation flow field as an initial condition. Is it cause to error or decrease solution time? (It is segregated and steady flow) Anyone has experience about it? Thanks ^^ Halit, |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
It varies with what software you are using how to actually do what you are saying. But yes, it's generally a good practice to do so.
Can it decrease simulation time? Absolutely. Does it cause any errors? Not any new errors that you wouldn't have encountered anyway. |
Halit Guvenc
I am using Star ccm+. Thank you for reply
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. | Nkl | OpenFOAM Running, Solving & CFD | 19 | October 10, 2019 02:42 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
