Impeller fluid domain mesh deformation
Old   December 1, 2021, 09:13
Default Impeller fluid domain mesh deformation
mohamed
chtabz11 is on a distinguished road
Hello
Im trying to run CFD analysis on the impeller. The impeller was imported as a step file and the fluid domain was created manually. I created the a mesh with a body size of 0.5mm and method of "body fitted cartesean" and the inflation was created automatically due to the method chosen. When I opened itof CXF pre the impeller blades look damaged. Is this a a visual bug or an actual mesh deformation. I have attached images. Thank you for your help in advance.
chtabz11 is offline   Reply With Quote
Old   December 1, 2021, 10:07
tundradot is on a distinguished road
Could it be that the mesher removes cells below a certain size that would be required at the blade tips?
tundradot is offline   Reply With Quote
cfd, deformation, fluid domain, impeller, mesh
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
