November 23, 2021, 14:24 |
Q-criterion in Tecplot360
ioannis filippou
Rep Power: 5 |
Hello everyone, i want to make clear that i am pretty new to CFD so my question might be idiotic.
I am using tecplot360 in order to make a 3D plot of the wake behind a wind turbine and more precisely i want to model the vorticity. I have a ".dat" file and i want to load it with the PLOT3D loader in order to calculate the Q-criterion since i read online that this variable is available only in this loader. So my question is how do i convert the .dat file into a file type that can be loader with the PLOT3D loader. Thank you in advance. |
November 24, 2021, 00:51 |
Lucky
Rep Power: 66 |
From where does this ".dat" file originate? .dat is not a standardized format and is informally recognized as a text file with data in it.
Can't help you with PLOT3D if you are asking how to use PLOT3D. But Q-criterion can be calculated using tecplot tools. |
November 24, 2021, 06:25 |
#3 | |
ioannis filippou
Rep Power: 5 |
My .dat file originates from a gfortran code that i am running (lifting line method) and it contains the velocity field in the wake of a wind turbine. So what i want to do is calculate Q. What i have achieved so far is to calculate lambda2, which is an alternative to the Q, through a specified set of equations by the use of the second (in magnitude) eigenvalue. There are two ways to go about using the Q criterion. 1) Manage to load my input file with PLOT3D and use the calculate variables tab (Q-criterion variable) 2) Change the equations set that are used for the lambda2 criterion to make them calculate Q. Any ideas on how to do one of those two alternatives? Thank you in advance |
November 24, 2021, 11:59 |
Lucky
Rep Power: 66 |
Or... you know, you could just calculate it. I saw in another thread (rant: why do people always do this!?) that you were looking for the macro to do this...
Here is the download link for Qcriterion.mcr If you can calculate lambda-2, you can calculate Q-criterion. Actually you calculate something very closely related to Q-criterion along the way to get lambda-2. |
November 24, 2021, 17:50 |
#5 | |
ioannis filippou
Rep Power: 5 |
I found the equations for Q-criterion. By the way the link you sent does not work. |
November 24, 2021, 19:18 |
Lucky
Rep Power: 66 |
Try copying the link into your browser directly. Check pop up blockers. Try another browser. I don't know why the internet doesn't work for you.
November 24, 2021, 19:20 |
Lucky
Rep Power: 66 |
Heck I dump the scipt here. All rights reserved by their owners.
#!MC 1400 # Created by Tecplot 360 build 14.0.2.35002 $!ALTERDATA EQUATION = '{Q} = 0' $!VarSet |NUMVARSINIT| = |NUMVARS| $!VarSet |NUMVARSINIT| += 1 $!PROMPTFORTEXTSTRING |U| INSTRUCTIONS = "Enter the variable number for U" $!PROMPTFORTEXTSTRING |V| INSTRUCTIONS = "Enter the variable number for V" $!PROMPTFORTEXTSTRING |W| INSTRUCTIONS = "Enter the variable number for W" $!GLOBALTHREEDVECTOR UVAR = |U| $!GLOBALTHREEDVECTOR VVAR = |V| $!GLOBALTHREEDVECTOR WVAR = |W| $!ALTERDATA EQUATION = '{dudx} = ddx(u)' $!ALTERDATA EQUATION = '{dvdx} = ddx(v)' $!ALTERDATA EQUATION = '{dwdx} = ddx(w)' $!ALTERDATA EQUATION = '{dudy} = ddy(u)' $!ALTERDATA EQUATION = '{dvdy} = ddy(v)' $!ALTERDATA EQUATION = '{dwdy} = ddy(w)' $!ALTERDATA EQUATION = '{dudz} = ddz(u)' $!ALTERDATA EQUATION = '{dvdz} = ddz(v)' $!ALTERDATA EQUATION = '{dwdz} = ddz(w)' $!ALTERDATA EQUATION = '{s11} = {dudx}' $!ALTERDATA EQUATION = '{s12} = 0.5*({dudy}+{dvdx})' $!ALTERDATA EQUATION = '{s13} = 0.5*({dudz}+{dwdx})' $!ALTERDATA EQUATION = '{s22} = {dvdy}' $!ALTERDATA EQUATION = '{s23} = 0.5*({dvdz}+{dwdy})' $!ALTERDATA EQUATION = '{s33} = {dwdz}' $!ALTERDATA EQUATION = '{Omga12} = 0.5*({dudy}-{dvdx})' $!ALTERDATA EQUATION = '{Omga13} = 0.5*({dudz}-{dwdx})' $!ALTERDATA EQUATION = '{Omga23} = 0.5*({dvdz}-{dwdy})' $!ALTERDATA EQUATION = '{s2o2_11} = {s11}**2 + {s12}**2 + {s13}**2 - {Omga12}**2 - {Omga13}**2' $!ALTERDATA EQUATION = '{s2o2_12} = {s11}*{s12} + {s12}*{s22} + {s13}*{s23} - {Omga13}*{Omga23}' $!ALTERDATA EQUATION = '{s2o2_13} = {s11}*{s13} + {s12}*{s23} + {s13}*{s33} - {Omga12}*{Omga23}' $!ALTERDATA EQUATION = '{s2o2_22} = {s12}**2 + {s22}**2 + {s23}**2 - {Omga12}**2 - {Omga23}**2' $!ALTERDATA EQUATION = '{s2o2_23} = {s12}*{s13} + {s22}*{s23} + {s23}*{s33} - {Omga12}*{Omga13}' $!ALTERDATA EQUATION = '{s2o2_33} = {s13}**2 + {s23}**2 + {s33}**2 - {Omga13}**2 - {Omga23}**2' $!ALTERDATA EQUATION = '{Q} = 2*{Omga12}**2 + 2*{Omga13}**2 + 2*{Omga23}**2 - {S11}**2 - {S22}**2 - {S33}**2 - 2*{S12}**2 - 2*{S13}**2 - 2*{S23}**2' $!VarSet |NUMVARSFIN| = |NUMVARS| $!DELETEVARS [|NUMVARSINIT|-|NUMVARS|] |
November 25, 2021, 05:39 |
#8 | |
ioannis filippou
Rep Power: 5 |
These are the ones that i have {Ω}= (0.5*{dudy}-0.5*{dvdx})**2+(0.5*{dudz}-0.5*{dwdx})**2+ (0.5*{dvdx}-0.5*{dudy})**2+(0.5*{dvdz}-0.5*{dwdy})**2+ (0.5*{dwdx}-0.5*{dudz})**2+(0.5*{dwdy}-0.5*{dvdz})**2 {S}={dudx}**2+(0.5*{dvdx}+0.5*{dudy})**2+(0.5*{dwd x} +0.5*{dudz})**2+ (0.5*{dvdx}+0.5*{dudy})**2+{dvdy}**2+(0.5*{dwdy}+0 .5*{dvdz})**2 + (0.5*{dwdx}+0.5*{dudz})**2+(0.5*{dwdy}+0.5*{dvdz}) **2+{dwdz}**2 {Q}=0.5*({Ω} - {S}) Last edited by john filippou; November 25, 2021 at 08:14. |
November 25, 2021, 16:20 |
#9 |
Lucky
Rep Power: 66 |
I don't understand this tone. They're not my equations. If you have an issue then take it up with tecplot. I don't work for tecplot.
November 25, 2021, 17:09 |
#10 |
ioannis filippou
Rep Power: 5 |
What is weird about my tone? I just said thank you for taking the time to answer and even post the equations. Its all good.
December 10, 2021, 05:40 |
#11 | |
Rep Power: 11 |
That's not correct. You can calculate the Q-criterion under "Analyze" -> "Calculate variables" no matter the data format of the file (since Tecplot 2017R2). Why should the data format matter anyway? |
December 14, 2021, 07:45 |
#12 |
ioannis filippou
Rep Power: 5 |
Well Q-criterion does not appear in the list of variables..i solved the issue via the qcriterion equations. Thank you anyway
[General] 3D plot Q criterion | Ursmooth | ParaView | 1 | November 25, 2021 15:42 |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 10:48 |
Stopping criterion for outer iteration loop | luftraudi | Main CFD Forum | 3 | February 22, 2017 09:59 |
Asymptotic stopping criterion is not working | rob50904 | STAR-CCM+ | 2 | January 28, 2013 09:25 |
convergence criterion | Dominique | FLUENT | 5 | November 24, 2006 03:36 |
