November 12, 2021, 09:04 |
Looking for a non-parabolic circular flow
Sebastian
Rep Power: 4 |
Hi guys and gals,
I am currently working on a (at least for me) hard homework. Without going to much into detail: Working with Stokes flow, I am trying to implement a superposition-solution for a very specific microfluidic problem. For that, I need a velocity-field in polar-coordinates with, that is not parabolic. My first try was to work my way through the Navier-Stokes-equations, implementing the following properties: - flow is incompressible - very low Reynolds number - flow is fully developed - flow is stationary - non-rotational - no angle-dependent flow changes So, I ended up with a Hagen-Poiseuille (HP) flow. That is, however, not really what I need, since is not linear in relation with the radius. In 2-D I could implement a Couette-flow without a problem. Could that maybe be a solution for a circular flow itself? Maybe I need to combine HP with Couette or something? To sum up: I am looking for a velocity-field w(r,phi) that has a linear dependence on r. Oh man I am lost on that. Maybe I am just overthinking. Thank you sooo much. I would really appreciate the help. |
November 13, 2021, 01:50 |
Itīs done
Sebastian
Rep Power: 4 |
Hey,
I have found a solution. Turns out, I was actually just overthinking stuff. Simply writing down the question helped a lot, though. So cheers and have a nice weekend. Thread can be closed. Cheers! |
couette flow, creeping flow, hagen poiseuille, stokes flow |
Velocity Profile for flow over circular cone | rameshbhoraniya | FLUENT | 3 | March 30, 2016 02:11 |
Two-phase flow in a circular horizontal pipe | DmitryS | Fluent Multiphase | 0 | May 17, 2014 16:22 |
parabolic flow | Mahe | Phoenics | 0 | September 2, 2009 09:53 |
Poiseuille flow (flow in a pipe) in SOLA-VOF. Parabolic distribution of velocities. | Anton | Main CFD Forum | 9 | April 29, 2009 10:31 |
3D parabolic equation for fluid flow | Nelly | FLUENT | 3 | January 22, 2007 14:03 |
