November 8, 2021, 11:31 |
sonicDyMFoam problem in foam-extend 4.1
Amr Emad Ezzat
Rep Power: 7 |
Hello Everyone,
I'm trying to use sonicDyMFoam in foam-extend 4.1 to compress some air inside a cylinder. However, I noticed a weird behavior when I apply a movingWallVelocity boundary condition or even a fixed uniform velocity to certain boundaries. This behavior is not existing in the OpenFOAM v2106 ESI version for the same problem using the same solver "name". It seems that the sonicDyMFoam version in foam-extend has a problem applying this boundary condition and applying it to the next cell near the wall. Has anyone tried to solve this problem before? Thanks a lot in advance! https://drive.google.com/file/d/12kv...ew?usp=sharing |
cfd, foam-extend 4.1, openfoam |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 12:04 |
Block coupling three equations using foam extend 4.1 | ELwardi | OpenFOAM Programming & Development | 2 | March 19, 2019 11:35 |
[swak4Foam] undefined symbols in .so libraries when compiling swak4foam 0.4.2 on foam extend 4.1 | mAlletto | OpenFOAM Community Contributions | 3 | August 29, 2018 07:02 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
