The sign of the total forces acting on an object in OpenFOAM
Old   October 31, 2021, 18:46
Default The sign of the total forces acting on an object in OpenFOAM
NotOverUnderated's Avatar
ONESP-RO
NotOverUnderated is on a distinguished road
I have a small issue with the sign of the total force acting on an object. I have used OpenFOAM to compute the forces. I have also computed the wall Shear Stress field on that surface.
I am trying to compute the same total force but in paraview by integrating the following:
-rho*p*Normals + rho*wallShearStress
I get the exact same result compared to the one computed by OpenFOAM except the sign is the opposite.
so in order to get the same results as OpenFOAM I had to do:
rho*p*Normals - rho*wallShearStress
Could someone please clarify why the sign is inversed? because as far as I understand the minus should appear in the first term not the second.
I am grateful to your help
NotOverUnderated is offline   Reply With Quote
Old   October 31, 2021, 20:09
ONESP-RO
Well done Paraview well done!
It turns out that Paraview inverses the surface normals! I had to flip them and use the "correct formula":
And then integrate that over the surface to get the exact same result compared to OpenFOAM results.
(See the attached image to see the flipped normals )
[OpenFOAM.org] Instructions to install OpenFOAM-2.4.x on CentOS-6.10 redbullah OpenFOAM Installation 9 September 7, 2019 18:18
getting wrong forces and force coefficients in openfoam maddy11 OpenFOAM 2 January 23, 2019 02:09
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
