October 30, 2021, 11:31 |
UDF code
AHMED KANDIL
Rep Power: 5 |
Hello every one ,
This code I do it to calculate inlet temp based on outlet temperature but there are a large divergence has occurred so what is the problem ? i need from this code inlet and outlet temp for 252000 second. the first assumption for inlet temp=288.15k and this temp will reduced as fluid pass through borhole and the outlet temp used again to calculate inlet temp from heating equation and still working to decrease error and give accurate outlet and inlet temp. noted that ID=17 is outlet temp. #include "udf.h" #define Q 5600 #define m 0.248 #define Cp 4200 #define stop_time 252000 real ave_T; DEFINE_ADJUST(temp_ave, domain) { int ID = 17; int i=0; real total_temp = 0; real T; Thread *thread = Lookup_Thread(domain, ID); face_t face; begin_f_loop(face, thread) { T = F_T(face, thread); total_temp = total_temp + T; i = i + 1; } end_f_loop(face, thread) ave_T = total_temp / i ; printf("outlet average of temp : %f\n" , ave_T); } DEFINE_PROFILE(Temp_inlet,t,i) { face_t f; real current_time; current_time=CURRENT_TIME; if (current_time < stop_time) { begin_f_loop(f,t) { F_PROFILE(f,t,i)= (Q/(m*Cp)) + ave_T; } end_f_loop(f,t) } else { begin_f_loop(f,t) { F_PROFILE(f,t,i)= 288.15; } end_f_loop(f,t) } } this the error[erature using GMRES to enhance linear solver robustness. Divergence detected in AMG solver: temperature turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 56612 cells outlet average of temp : -nan(ind) Divergence detected in AMG solver: temperatureoutlet average of temp : -nan(ind) Divergence detected in AMG solver: temperatureoutlet average of temp : 5000.000000 Divergence detected in AMG solver: temperatureoutlet average of temp : -nan(ind) Divergence detected in AMG solver: temperatureoutlet average of temp : -nan(ind) Divergence detected in AMG solver: temperatureoutlet average of temp : -nan(ind) Divergence detected in AMG solver: temperature Error at host: floating point exception Error at Node 0: floating point exception Error at Node 1: floating point exception Error at Node 2: floating point exception Error at Node 3: floating point exception Error at Node 4: floating point exception Error at Node 5: floating point exception Error at Node 6: floating point exception ===============Message from the Cortex Process================================ Compute processes interrupted. Processing can be resumed. ================================================== ============================ Error: floating point exception Error Object: #f Registering Udf, ("F:\Eng.Ahmed Kandiel\UDF.c") Calculation complete.] |
Parse error in UDF Code | Sharey | FLUENT | 3 | July 23, 2020 12:47 |
UDF warning C4027- CG motion code | Me_1989 | Fluent UDF and Scheme Programming | 11 | May 29, 2020 15:56 |
UDF code help solve reaction rate equation palm oil | zirkov | Fluent UDF and Scheme Programming | 0 | February 13, 2017 11:34 |
write code UDF Fluent solve kinetic reaction rate equation palm oil | zirkov | FLUENT | 0 | February 13, 2017 11:16 |
How to transfer a 2D UDF code into 3D? | Jo_vivian_lee | Fluent UDF and Scheme Programming | 0 | August 26, 2012 04:36 |
