Hamish
Rep Power: 5 ![]() |
I'm simulating a small rocket nozzle and currently conducting a grid convergence study of my simulation. I'm using a plot of thrust along the outlet plane (in the radial direction) to evaluate the different grids.
However, I would like a single value of thrust to make it easier to compare. How can I calculate an averaged thrust? |
Alex
Rep Power: 49 ![]() ![]() |
In order to get a thrust value with Newton as a unit as the plot suggests, you need to integrate over the area anyway. Which is what I would suggest to get a single value for thrust.
grid convergence study, nozzle thrust |
Converging Diverging Nozzle with dbnsTurbFoam | Saleh Abuhanieh | OpenFOAM Running, Solving & CFD | 4 | December 13, 2019 10:26 |
calculating average on a createpatch totposet without disturbing simulation results | momentum_equation | OpenFOAM Post-Processing | 0 | July 18, 2019 02:56 |
Inverse Design Optimization | khavart | SU2 Shape Design | 0 | June 20, 2019 03:37 |
Calculating frictional losses in cd nozzle | DA6righthand | Main CFD Forum | 3 | June 8, 2017 19:23 |
calculation of thrust thrugh a pipe with CD nozzle | izhar | Main CFD Forum | 0 | February 28, 2009 09:22 |
