October 27, 2021, 02:43 |
compressible interfoam PEqn.H
hari charan
Rep Power: 5 |
hello guys,
I am hari . I am working on compressible interfoam . I couldn't understand the pressure equation used in pimple algorithm in PEqn.H in compressible inter foam. can anyone help me explaining it. i am attaching the equation below. p_rghEqnComp1 =pos(alpha1) *( ( fvc::ddt(alpha1, rho1) + fvc::div(alphaPhi1*rho1f) - (fvOptions(alpha1, mixture.thermo1().rho())&rho1) )/rho1 - fvc::ddt(alpha1) - fvc::div(alphaPhi1) + (alpha1/rho1) *correction ( psi1*fvm::ddt(p_rgh) + fvm::div(phid1, p_rgh) - fvm::Sp(fvc::div(phid1), p_rgh) ) );thanks and regards |
December 29, 2021, 07:19 |
hari charan
Rep Power: 5 |
I understood the Equation. The problem is solved.
For people who have same doubt You can understand PEqn from below link Formulation in compressibleInterFoam . And also this link Formulation in compressibleInterFoam . Thanks and regards. Last edited by saicharan662000@gmail.com; January 5, 2022 at 08:27. |
openfaom |
compressible interfoam | saicharan662000@gmail.com | OpenFOAM | 1 | December 30, 2021 02:49 |
[Other] Compressible Interfoam | gtpunnamarajuaju@gmail.co | OpenFOAM Meshing & Mesh Conversion | 0 | July 13, 2016 16:15 |
k-e & GAMG interFoam Schemitisation Stability Issue | JFM | OpenFOAM Running, Solving & CFD | 3 | December 1, 2015 06:58 |
InterFoam with air fraction compressible | hsieh | OpenFOAM Running, Solving & CFD | 3 | March 15, 2013 18:00 |
Compressible interFoam | matthias_hofmann | OpenFOAM Running, Solving & CFD | 1 | May 11, 2009 16:20 |
