How to calculate the eigenvalues of the Jacobian matrix of the chemical source term |
October 26, 2021, 09:18 |
ocean-yang
Hi everyone:
As a cfd beginner I have a question about the Jacobian matrix of the chemical source term. There is a method called Chemical Explosive Model Analysis(CEMA), which judges the local combustion mode by analyzing the eigenvalues of the Jacobian matrix of the chemical source term.(reference: T. F. Lu , C.S. Yo o , J. H . Chen , C.K. Law , J. Fluid Mech. 652 (2010) 45–64 . ) Unfortunately, I only use the Fluent software, and I don’t know how to extract the chemical source term of the grid and calculate the eigenvalues of the Jacobian matrix, do I need the udf function? Or do I need to use other software? Looking forward to the guidance of people who understand the CEMA or those who understand the calculation of Jacobian matrix in the chemical source term, and welcome everyone to provide your ideas to exchange |
October 26, 2021, 13:25 |
Guruprasad S
Rep Power: 5 |
If you are looking for quick and dirty ways to calculate Eigenvalues there are a variety of numerical methods:
for example Von Mises iterations gives the largest eigenvalue of a matrix with great simplicity you need to hook up a UDF containing one of these routines written in C to Fluent,when the solver is running,you can make the UDF output the eigenvalues to your fluent terminal. I have not personally worked on this sort of problem but I believe you need to use certain header files and syntax for this. search for the fluent UDF manual,it pops up in a google search as for extracting variables you can put something like a sensor point in Fluent All the best! |
October 27, 2021, 02:39 |
ocean-yang
Thank you very much for your reply, I believe it will be of great help to me.
chemical source term, eigenvalues, jacobian matrix |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
Source term for EVAPORATION in Energy Equ. - technical difficulty ? | Kummi | OpenFOAM | 1 | September 9, 2019 09:32 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
