How to find centrifugal pump CAD geometry with experimental results for benchmarking?
Old   October 16, 2021, 12:26
Default How to find centrifugal pump CAD geometry with experimental results for benchmarking?
James Gross
jgross is on a distinguished road
Hi all,
I need to validate my CFD methodology used by comparing its performance to experimental results for a volute centrifugal pump without a diffuser (it's actually for a slurry pump, but a standard centrifugal pump is fine to use). Unfortunately, I do not have experimental results for the pump geometry I use in my studies and am having difficulty finding any cases where both CAD geometries and experimental results are provided.
Does anyone know of any repositories of centrifugal pump CAD geometries with experimental results I could use? Alternatively, if no such repository exist, do you know if there are any cases I could use for this purpose?
I have already investigated using a CAD repository, like GrabCAD, but the centrifugal pump geometries there do not have experimental results. I have also seen the ERCOFTAC centrifugal pump impeller OpenFOAM case study online (https://www.openfoamwiki.net/index.p...vaned_diffuser), but this geometry is for a diffuser and impeller combination without a volute, so is not suitable.
Thanks in advance for any help you can provide in pointing me in the right direction!
Cheers!
jgross is offline   Reply With Quote
Old   October 18, 2021, 13:47
James Gross
Any suggestions?
cad model, centrifugal pump, experimental data, slurry flow
Centrifugal Pump CAD Model Required for validation bhatiadinesh CFX 1 June 25, 2013 05:16
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Experimental & numerical results Amy CFX 2 September 1, 2005 09:52
stator-rotor interaction in the centrifugal pump G.H.Lee Main CFD Forum 4 May 25, 1999 08:33
