DDPM with periodic boundary conditions
Old   October 12, 2021, 17:56
Default DDPM with periodic boundary conditions
The_seeker is on a distinguished road
Hi All,
I wish to do particle simulations with periodic boundary conditions. I went through the documentation of Ansys Guide which says that:
'Streamwise periodic flow (either specified mass flow rate or specified pressure drop) cannot be modeled when the discrete phase model is used.'
I checked through some publications as well as some threads on this forum, people have been doing particle simulations with periodic boundary conditions. Is it possible that the text I quoted from guide is for some older version of Ansys fluent and the newer one do accommodate using periodic boundary conditions with particle simulations.
The_seeker is offline   Reply With Quote
Old   October 12, 2021, 18:07
Lucky
There are two kinds of periodic boundary conditions in Fluent.
One is the periodic interface BC that you think of mathematically. This one you can use.
The other is the streamwise periodic BC, which is an implementation of its namesake for streamwise periodically fully developed flow. Other software will call this the fully developed BC.
So you might have seen people do particle simulations with periodic BC's, but not streamwise periodic BC's.
Old   October 12, 2021, 18:44
Thank you very much for your quick response. I do have experience with setting periodic flow simulations in FLUENT. I either use the 'mesh-modify-zones-make-periodic' option to create periodic zones for conformal meshes or generate ' interfaces' for non-conformal ones. When you say there are two kinds of boundary conditions, that does not mean that setting up the case for either configuration is different, right?
Old   October 13, 2021, 04:58
Lucky
If you use the default translation setting, this actually creates the streamwise periodic BC for fully developed flow. If you set a pressure gradient of 0 then it is equivalent to a periodic BC for all practical purposes until one day you realize that this is not a normal periodic BC.
It's still not clear to me whether you want the streamwise periodic condition or not. Maybe you can clarify what your periodicity looks like. It's rather important because you can have translational/rotational periodicity and it can look very similar to a streamwise periodic case.
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 06:53
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
PEMFC module + multiple periodic boundary conditions vkrastev FLUENT 2 December 22, 2014 05:15
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
