Shear Stress on Rough Surface
Old   October 7, 2021, 05:45
Default Shear Stress on Rough Surface
Boqi Ren
Sylorn is on a distinguished road
Hi everyone
I'm writing here to ask some questions about the calculation of wall shear stress on the rough surface.
As we know, the definition of wall shear stress is
\tau_w= \mu (\frac{\partial u}{\partial y})_{y=0}
so for the rough surface, can I calculate the shear stress in the following way?
\tau_w= \mu (\frac{\partial u_t}{\partial n})_{y=0}
Where t means the tangential direction of the local surface, and n means the normal direction.
And, could you recommend some relative reference to me?
THANK YOU VERY MUCH!
Last edited by Sylorn; October 7, 2021 at 05:57. Reason: to correct the formulations
Sylorn is offline   Reply With Quote
Old   October 7, 2021, 12:05
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Sylorn View Post
Hi everyone
Since the surface is rough you should evaluate the normal derivative at x=x(s), y=y(s), not at y=0.
The action of the stress can be better see if you write the contribution of the stress tensor on a finite surface:
Int[S] n.Td dS
Td being the deviatoric part having zero trace.
FMDenaro is offline   Reply With Quote
Old   October 8, 2021, 00:45
Boqi Ren
Int[S] n.Td dS
FMDenaro, Thank you very much!
Yes, as you said, the wall shear stress should be on the wall, so in the second equation, y=0 is not correct.
But I still feel confused with \textbf{T}d. Could you explain this term in more detail?
Old   October 8, 2021, 12:25
Lucky
It's the tensor form of shear stress. du/dy the way Isaac Newton did it is for 1D.
rough wall, shear stress
Export Wall Shear Stress Data trooken FLUENT 6 February 5, 2019 16:09
Shear Stress Calculation in the flow. auburnuser FLOW-3D 11 May 12, 2018 14:49
Difference between Wall Shear Stress of No-slip and Rough Walls @E18 Main CFD Forum 2 March 5, 2018 12:57
How can I plot area averaged wall shear stress variation with time over a surface? Gourabc FLUENT 0 February 1, 2017 00:56
Fluid wall shear stress Sinead Kelly (Kelly) OpenFOAM Running, Solving & CFD 2 March 30, 2011 07:41
