create a pump curve
Old   October 7, 2021, 03:41
Default create a pump curve
Mads Bjørnenak
mbjornen is on a distinguished road
I am using solidworks flow and i want to create a pump curve of a propeller pump with high flow and low head. what is the principal way of creating a pump curve using CFD?
mbjornen is offline   Reply With Quote
Old   October 7, 2021, 04:05
Lucky
Just run a bunch of simulations with different operating conditions. You can sweep the pressure head and calculate the flow rate from the CFD or you can sweep the flow rate and calculate the pressure head, whichever you prefer. Then you plot the data of pressure head vs flowrate and that's your pump curve.
Setting up 3D simulation for external gear pump 310toumad FLUENT 2 February 5, 2019 10:12
Centrifugal pump Simulation in Cfx ; Head capacity curve not matching dileeps ANSYS 0 December 6, 2017 23:01
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 15:18
[GAMBIT] How to plot S pipe mariam.sara ANSYS Meshing & Geometry 36 November 7, 2013 16:22
CENTRIFUGAL PUMP, characteristic curve and radial forces curve tareqkh FLUENT 0 February 25, 2012 16:53
