oparallel in Xflow software, number of cpus
Old   September 29, 2021, 12:12
Default oparallel in Xflow software, number of cpus
Dung Feng
wodeqiche2007 is on a distinguished road
I'm using Xflow 2020x software.
Yesterday’s calculation of more than 400,000 grid CPUs used 90%, but today’s calculation of 570,000 grid CPUs only used about 30%
I want to know how It can use more CPU during analysis and so reduce the calculation time?
wodeqiche2007 is offline   Reply With Quote
Old   September 29, 2021, 21:06
Lucky
If there's too much overhead then the cores sit there waiting for memory to load and don't do any work.
But also check with your job scheduler and make sure there aren't any job collisions. Collisions become exponentially more frequent the more you load a cluster and you can imagine all 569 999 cores have finished and are all waiting for that last core to finish its calculation because it is running on a node that already has something else going on.
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
Decomposing error simple method DanGode OpenFOAM Pre-Processing 1 July 27, 2021 07:58
Foam-Extend 4.0 simpleFoam motorbike parallel error? EternalSeekerX OpenFOAM Running, Solving & CFD 0 May 10, 2021 05:55
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 11:27
