Wrong Pressure Distribution
Old   September 20, 2021, 19:44
Default Wrong Pressure Distribution
Shravana
shravana is on a distinguished road
Hi all! I have conducted an ICFD analysis of a 3 mm cooling channel using a Steady-State Solver. The image below is the fluid pressure result for boundary conditions: Inlet velocity = 1195.586 mm/s and Outlet pressure = 0 MPa.
As seen here, the pressure results are not consistent especially in the region near the inlet and the outlet. Can anyone help me recognize what could the reason be for this?
shravana is offline   Reply With Quote
Old   September 21, 2021, 08:37
Guvennergiz's Avatar
Guven Nergiz
Guvennergiz is on a distinguished road
Do you map the pressure values to Ls-Dyna mesh?
Guvennergiz is offline   Reply With Quote
Old   September 21, 2021, 08:39
Shravana
No, I did not map any pressure values. This result is based on the boundary conditions only.
Old   September 21, 2021, 08:48
Guven Nergiz
Because it looks LS-Dyna Pre-Post, maybe this is the problem. Otherwise I think its about the mesh...
Old   September 21, 2021, 08:53
Shravana
Yes, it is LS-Dyna but I did not map any pressure values. I have refined the mesh to 0.25 mm element size.
I have investigated a simple cylinder too and it gives me correct results.
cfd, cooling, pressure
Correct pressure distribution but wrong aerodynamics coefficients Aerospace OpenFOAM 11 December 12, 2012 06:05
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Pressure distribution over an airfoil-help Andrew Parker FLUENT 4 February 13, 2002 12:51
Effects of gravity in pipe - pressure distribution Anthony Wachs FLUENT 2 July 25, 2001 08:07
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
