Calculation dT for 2D2 Nielsen case
Old   September 20, 2021, 07:30
Question Calculation dT for 2D2 Nielsen case
Eugene
eugenzilio is on a distinguished road
Nielsen reports an indoor temperature profile for a series of low Archimedes numbers Ar [1]. We want to obtain dT, which is the temperature difference between the inlet and the outlet. We can calculate dT using the relation
Ar = \frac{\beta*g*dT*h}{{u}^{2}}
where
Ar = 1.1E-6 [-]
\beta= 0.0036 [-]
g = 9.81 [m/s^2]
h = 0.168 [m]
u = 0.647 [m/s]
This results in a dT=7.8E-5 degC. This is a very small temperature difference and it is unlikely that the sensor measurements carried out by Nielsen were that precise. This leads me to believe that there is something wrong. Has anyone, perhaps, worked with this case before? Perhaps the Archimedes number is wronglly reported?
[1] https://vbn.aau.dk/ws/portalfiles/po...ONED_ROOMS.pdf
Last edited by eugenzilio; September 20, 2021 at 10:00. Reason: Miscalculated beta
eugenzilio is offline   Reply With Quote
2d2, indoor, mixing ventilation, nielsen, validation
Calculation of lift and drag coefficients on airfoil CoolHersheys OpenFOAM Post-Processing 5 September 27, 2021 07:04
Copy material from case to case in Fluent mz_uon FLUENT 1 April 20, 2021 01:58
warning - extrapolating on temperature calculation cedame CONVERGE 2 September 5, 2016 12:55
How to evaluate the calculation time of CFX case unclewallcn CFX 3 April 17, 2016 07:35
Axial 2D calculation in simpleFoam prblem with convergence rybakov OpenFOAM Running, Solving & CFD 3 May 16, 2005 03:00
