Closed loop heat exchanger in fluent
Old   August 23, 2021, 01:30
Default Closed loop heat exchanger in fluent
Abhinay
soankerabhinay is on a distinguished road
I am trying to figure out how to create a closed loop heat exchanger model in fluent. My problem with the closed loop system is that my inlet temperature should be updated based on the outlet temperature at every timestep.
See the image below, I want to project outlet temperature profile on to the inlet boundary at every timestep.
I am actually surprised not to find a tutorial on a closed loop heat exchangers. Any help is appreciated.
soankerabhinay is offline   Reply With Quote
CFD Fluent tutorial - Shell and tube heat exchanger - PROBLEM tom96 FLUENT 1 May 21, 2018 01:24
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Define a Counterflow heat exchanger in FloEFD Kylbalsam FloEFD, FloWorks & FloTHERM 1 August 16, 2016 09:46
2D model of a tube in tube heat exchanger in fluent raveesh FLUENT 1 July 9, 2014 09:11
Simulation flow loop of Heat exchanger lalolala FLUENT 1 November 22, 2012 00:53
