Fluent 3d analysis problem
Old   August 11, 2021, 09:22
Unhappy Fluent 3d analysis problem
f.m.g.
fmgunkan is on a distinguished road
My computer has AMD ryzen 5950x processor and 64Gb ram. I also have an AMD Radeon RX 580 2048SP graphics card.
My 2d fluent analyzes are running smoothly.
In 3d analysis work, there is no problem in creating a large number of mesh structures, there is no problem in initializing and other operations. but before the first iteration fluent closes itself. I also used the student license, I used the company license, in the same way, it waits 30 minutes without the first iteration, and then the fluent closes. do you have an opinion on this? I am trying to do compressible gas analysis.
fmgunkan is offline   Reply With Quote
Old   August 11, 2021, 09:33
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
How many cells are we talking about here? Any error messages from log files?
flotus1 is offline   Reply With Quote
Old   August 11, 2021, 09:47
f.m.g.
Thank you for reply,
Mesh method is Multizone,
It has inflation , option is "First Layer Thickness, Layer Height : 0,003mm, maximum layers :15
Edge sizing type is "element type, size : 1mm"
Mesh max. face size is 3mm,
nodes: 27486257
elements : 26790500
Error [node 999999] [time 7/18/21 13:18:46] Abnormal Exit!
Error [node 999999] [time 7/18/21 18:15:11] Abnormal Exit!
Old   August 11, 2021, 14:52
flotus1's Avatar
Alex
26 million cells in Fluent can be too much for 64GB of RAM, depending on solver settings.
Check if your mesh is valid before trying to run the simulation. Then use a coarser mesh in the 10 million cell range.
If that still doesn't run, the problem must be something else. Incompatible solver settings, broken Fluent installation, hardware problems...
Old   August 12, 2021, 08:29
f.m.g.
ok, i will try your suggestion.
I write the positive or negative result.
Old   August 25, 2021, 12:47
f.m.g.
yes, as you said, when you brought the mesh element number to around 3-4m, the analysis worked.
This time, I had problems with the mesh quality settings. The aspect ratio is too high.
skewness and orthogonal quality are at an appropriate level.
note: when I do ansys benchmark on my computer, the analysis times are taking longer than normal. When I installed AMD's drivers and adjusted their settings, Fluent started to work more stable.
how to run fluent from matlab without using aas toolbox? artemis96 ANSYS 7 May 23, 2022 13:16
Stefan problem using fluent Isaacibp1401 Fluent Multiphase 2 June 7, 2021 06:49
Hydrodynamic analysis of submarine model with ANSYS FLUENT? Sovereignty ANSYS 0 January 20, 2019 19:36
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 21:23
fluent convergence problem josip76 FLUENT 0 May 26, 2011 21:08
