August 11, 2021, 04:03 |
How to solve pressure correction equation?
Rep Power: 5 |
I want to figure out the numerical method to solve the following pressure correction equation for cavitating flow. ( Plz see the attached file )
The equation is about p'(just pressure) and the other variables are known. For short, I guess it can be expressed like that : A*Laplacian(p')+B*p'=C (A,B,C are known variables) I guess it looks similar with Helmholtz equation,, same thing after all? For your info, the equation is refered to by the journal paper 'Computations of partial and super cavitating flows using implicit pressure-based algorithm (IPA)' Give me any advice, please. Thank you. |
August 11, 2021, 11:48 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
The equation should be seen as Div (f*Grad), and discretized as it is, not as laplacian. Be careful, you have to provide also the correct BCs. |
numerical, pressure |
Pressure fields in FOAM, p field, total pressure, etc. | Tobi | OpenFOAM Post-Processing | 9 | March 25, 2022 02:33 |
Having troubles in understanding the correction term in pressure equation | kaifu | OpenFOAM | 1 | October 8, 2012 06:19 |
Non-linearity Pressure Equation -- PISO algorithm | gdeneyer | OpenFOAM Programming & Development | 1 | August 23, 2012 06:19 |
Pressure correction equation,Ferziger and Peric | Hooman | Main CFD Forum | 1 | July 20, 2010 06:21 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
