Ship Longtitudinal Centre of Gravity Position |
August 2, 2021, 13:52 |
Rob Wilkinson
Rep Power: 6 |
If the Longtitudinal Centre of Gravity of a ship (without added load) is behind (aft) of it's Longtitudinal Centre of Flotation, does this affect a ships change in aft draft ?
For change in draft aft calculations, does added weight always have to be added at Longtitudinal Centre of Flotation, parallel sinkage calculated there and then change in trim calculation for movement of weight to it's actual position done from there ? or Can an Added weight be positioned at the ships original Longtitudinal Centre of Gravity, Parallel sinkage calculated at LCG and then the change in trim calculation for movement of weight to it's actual position done from there ? I am thinking of a situation when it is calculated that a cargo load is to be positioned aft of the ship Longtitudinal Centre of Gravity, when the ship Longtitudinal Centre of Gravity is behind Longtitudinal Centre of Flotation. Last edited by Rob Wilk; August 3, 2021 at 03:24. Reason: Comma after last Longtitudinal Centre of Gravity |
ship stability |
DTCHull (centre of gravity) | guzman | OpenFOAM Running, Solving & CFD | 3 | April 21, 2021 03:28 |
Longtitudinal Centre of Gravity for Ship Cargo | Rob Wilk | Main CFD Forum | 0 | April 29, 2020 02:42 |
Calculate Bubbles Centre position and Velocity | arsalan.dryi | OpenFOAM Post-Processing | 2 | May 21, 2016 06:28 |
Position of the center of gravity | dam114 | Fluent UDF and Scheme Programming | 0 | September 25, 2013 11:27 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
