Variable Inlet Flow Direction
Old   July 28, 2021, 14:52
Smile Variable Inlet Flow Direction
Vangelis
Baggos53 is on a distinguished road
Hello Everyone
I am running a simulation where the inlet region is a rectangular and I would like to know if I can have the inlet flow direction to vary along the height of the rectangular. More specifically the bottom side of the rectangular should have a flow angle of 60 degrees while the top side 50 degrees. The flow angle should change gradually from 60 and reaching the top with 50 degrees. Can someone give me some advice on how I can perform such a condition ?
Thank you !!
Baggos53 is offline   Reply With Quote
Old   July 28, 2021, 15:19
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
If you make the inlet form different blocks you have several inlet faces. Every of them may have another b.c.
That is the simplest way.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   July 28, 2021, 17:03
Lucky
Also depends what software you are using...
How about a .csv table of x,y,z components at different positions that you generate beforehand, load this into whatever software you are using, and use that as the BC?
Or directly program the functional relationship and use that.
boundaries condition, cfd -post, flow direction., inlet bc
ERROR: Flow direction on the boundaries must not be tangential to the boundary. turbomax CFX 3 October 27, 2024 07:19
Reversed flow using pressure inlet and outlet? here_for_help FLUENT 0 September 28, 2018 16:20
UDF for variable mass flow inlet boundary condition cfd_steve FLUENT 0 April 14, 2017 02:08
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
