SSIIM 1 - Error in continuity-ssimple
Old   July 25, 2021, 09:56
Question SSIIM 1 - Error in continuity-ssimple
Joana
joanaCFD is on a distinguished road
I'm using SSIIM software to simulate the flow field in a diversion channel (where the flow is extracted from the main channel - opposite case of a confluence). I have a topography measured from a laboratory experiment, which I use as the bed in my simulations (with the topography I created the geodata file, and then the koordina file). So, I have a fixed and deformed bed (with a big cavity downstream of the diversion entrance).
Some of the data sets I use in the control file are (steady computations):
F 16 0.00338 grain roughness
G 7 0 1 35 68 2 20 0 0 0.029 1.0 0.0 0.0 inflow area
G 7 1 -1 35 68 2 20 0 0 0.023 1.0 0.0 0.0 outflow area
G 7 1 2 140 152 2 20 0 0 -0.006 0.0 -1.0 0.0 side outflow area
G 13 1 2 139 2 34 2 20 outblock
G 13 1 153 399 2 34 2 20 outblock
I also use W 4 data set to define a wall for every side of the out blocks I defined, and data sets G 6 and K 1 for a moving water surface.
In the attachments, there is a figure with the grid.
After thousands of iterations, my runs stop, returning, in the boogie file, the message "Error in continuity-ssimple". I've tried to figure out what causes this error, but I didn't succeed. Does anyone know what could lead to this?
Thank you in advance for your attention and any help!
joanaCFD is offline   Reply With Quote
continuity, error, ssiim
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
