mixing studies
Old   July 14, 2000, 12:32
Default mixing studies
Kai Kang
I am recently getting into mixing CFD studies, simulation of mixing tanks with impellers.
I am looking for information about criteria used in judging the mixing effects and some novel studies. Can anyone recommend some papers/books for some bkground review. Thanks a lot.
Kai
Old   July 17, 2000, 11:58
Default Re: mixing studies
Ruben Nicolas Lopez
you may review the paper Turbulent flow in agitated vessel, Harvey & Greaves, Trans IChemE, vol 60, pp.195- 1982
mixing plane model: too much backflow and does not converge sbhi FLUENT 1 December 4, 2014 01:31
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 15:31
Meshing a Mixing Plane using ICEM Will Anderson FLUENT 0 November 6, 2010 18:08
turbine efficiencies, conservation rules across mixing planes Jonathan FLUENT 0 October 4, 2010 10:04
Mixing plane geometry definition Hbet FLUENT 0 January 18, 2002 08:16
