idea for meshing a plate heat exchanger
Old   June 17, 2021, 13:06
Default idea for meshing a plate heat exchanger
Mouna
Mounarah is on a distinguished road
i need your help for meshing a rectangular plate heat exchanger circulated by a serpentine path. I want to have an hexahydral mesh on fluid domain flowing in the serpentine and tetra on the other domain of a phase change material.
Because i'm not familiar with ICEM meshing, I would like to know if it is possible, in ansys meshing, to do a tetra mesh for all the systen even though it is less accurate than hexa for fluid domain or the second method is to do an hexahydral mesh in the serpentine with the method of slicing the tube into 5 bodies and then couple them in one part and apply multizone mesh and for the rectangular domain i will keep a terta meshing as mentionned.
for the second approach, i'm not sure if the slicing of the sepentine would affect the interface between the two domains and if it is applicable for transient state. thank you
the lin of the system modelling is below; https://www.cjoint.com/c/KFrqoQgqt8j
here is the link of slicing the serpentine for a simple reduced similar system with a Ubend tube, into 5 parts; https://www.cjoint.com/c/KFrsBXr6AKj
here is the limk of the preliminary automatic mesh to show that there is 4 contact regions; https://www.cjoint.com/c/KFrsEd7JUVj
Mounarah is offline   Reply With Quote
Plate Heat Exchanger Cell Zones Help CFDnewcomer FLUENT 1 March 28, 2019 07:19
Define a Counterflow heat exchanger in FloEFD Kylbalsam FloEFD, FloWorks & FloTHERM 1 August 16, 2016 09:46
Plate heat exchanger Temperature issue nidhin5585 Main CFD Forum 0 May 19, 2014 16:22
Plate heat exchanger Temperature issue nidhin5585 FLUENT 0 May 19, 2014 16:21
Plate fin heat exchanger ajay dehriya FLUENT 0 December 15, 2007 10:12
