June 14, 2021, 10:59 |
Wall resolved epsilon
Lorenzo
Rep Power: 5 |
Hello to all
I am trying to complete a solved simulation on the wall and I set all parameters related to turbulence, k (1e-8), Epsilon(1e-10), nut(1e-10), alphat(1e-10). But I noticed that it creates a peak near the relative wall of epsilon. Considering that I still get a value of Y+ close to 1 to what might be related problem ? Thanks a lot for the reply |
June 14, 2021, 11:53 |
Alex
Rep Power: 49 |
What does the computational domain look like?
Which boundary conditions are you using? Where did you evaluate the results shown in the chart? What's a relative wall? |
June 14, 2021, 12:49 |
Lorenzo
Rep Power: 5 |
Hi
My 2D domain includes two coaxial injectors from which methane and oxygen come out, in all the walls I used the condition of viscosity and velocity zero, while the values of k, nut, alphat are fixed with fixedValue. The epsilon graph is reported from the axis to the upper wall, so the x axis is the spatial coordiante and the y axis is the value of epsilon, but this condition occurs on all walls and only on the epsilon. thanks for the reply |
June 14, 2021, 13:35 |
Alex
Rep Power: 49 |
Could you elaborate what the problem is? It is to be expected that the value of epsilon has a maximum close to the wall.
openfoam, reactingfoam, wall resolved |
Divergence in AMG solver! | marina | FLUENT | 20 | August 1, 2020 11:30 |
Blowing up epsilon using wall BC interfoam | josee | OpenFOAM Running, Solving & CFD | 3 | May 15, 2017 00:39 |
Grid difference between wall modeled LES and wall resolved LES | hityangsir | Main CFD Forum | 9 | April 17, 2015 11:59 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
